[GRASS5] problems with grasslinks
Anand Mohan
anand at mail.arkinsys.com
Tue Jan 22 23:15:24 EST 2002
hi
I am trying to make GrassLinks work in my computer and
have finished the configured job for local site. I can
get the correct select menus (&display1) , but for
&display2, no "grasslinks.$$.gif" is created (the size
is zero).
I get through the scipts and feel a little confused by
the sub_function "create_gif":
sub create_gif {
&system_silent("p.select ppm 1>/dev/null");
&system_silent("p.map.new
input=$TMP/$value{PMAP_SCRIPT} 1> /dev/null");
#run ppm program to create gif
&system_errors_logged("$PBM_PATH/ppmquant 256 <
$ENV{MAPLP} 2> /dev/null | $PBM_PATH/ppmtogif
-interlace > $TMP/$value{GIF} 2> /dev/null");
$ENV{MAPLP} is not initialized in the whole scripts,
can it be an input file?
If it is an input file what it contains actually?
I try to run "p.select ppm 1>/dev/null" directly in
the grass terminal, and it give two errors: one is for
"ppm", because only painter "preview, preview2" exist,
another is for "1", it is regarded as a wrong
parameter.
I know that many people have run the Grasslinks
successfuly, could anybody tell me how to make it
work?
Thanks.
