[GRASS5] Projection transform
Glynn Clements
glynn.clements at virgin.net
Wed Jan 23 04:44:20 EST 2002
Markus Neteler wrote:
> ...just an addition: There is also m.proj2 which is the command line
> version of m.proj.
Is there any significant reason why these aren't cmd/inter versions of
a single program?
Certainly, they have a lot of common code (geo_func.c and get_deg.c
are identical, process.c differs only in whitespace, get_stp.c differs
only due to debugging statements).
Glynn Clements <glynn.clements at virgin.net>
