[GRASS5] problems with grasslinks
Alex Shevlakov alex at asrv.fcpf.ru
Wed Jan 23 05:55:20 EST 2002
You might have the wrong version of lib pbm/pnm/pgm library;
you might not have it at all. So check if its there.
If yes, just run ppmtogif to see if shared libs are loaded.
The source code which I gave as example called
'webgrass' uses shell not perl. It's easier work
to debug your ppmtogif conversion error.
And of course you MUST have ppm painter compiled within
grass code.
--alex
--- Anand Mohan <anand at mail.arkinsys.com> wrote:
> hi
> I am trying to make GrassLinks work in my computer
> and
> have finished the configured job for local site. I
> can
> get the correct select menus (&display1) , but for
> &display2, no "grasslinks.$$.gif" is created (the
> size
> is zero).
> I get through the scipts and feel a little confused
> by
> the sub_function "create_gif":
> sub create_gif {
> &system_silent("p.select ppm 1>/dev/null");
> &system_silent("p.map.new
> input=$TMP/$value{PMAP_SCRIPT} 1> /dev/null");
> 	#run ppm program to create gif
> &system_errors_logged("$PBM_PATH/ppmquant 256 <
> $ENV{MAPLP} 2> /dev/null  | $PBM_PATH/ppmtogif
> -interlace > $TMP/$value{GIF} 2> /dev/null");
> $ENV{MAPLP} is not initialized in the whole scripts,
> can it be an input file?
> If it is an input file what it contains actually?
> I try to run "p.select ppm 1>/dev/null" directly in
> the grass terminal, and it give two errors: one is
> for
> "ppm", because only painter "preview, preview2"
> exist,
> another is for "1", it is regarded as a wrong
> parameter.
> I know that many people have run the Grasslinks
> successfuly,  could anybody tell me how to make it
> work?
> Thanks.
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020123/19ca1501/attachment.bin
