[GRASS5] Re: Solaris2.8 compile problems
Palle Haastrup palle.haastrup at jrc.it
Thu Jan 24 03:08:28 EST 2002
Dear Markus, Dear Andreas, Dear "Grass5"
I am pleased to report that upgrading to gcc 3.0.3 cured the problem.
Palle
At 15:54 22/01/2002 +0100, Markus Neteler wrote:
>Hi,
>Palle Haastrup <palle.haastrup at jrc.it>, who kindly prepared
>SUN/Solaris binaries for the GRASS community (today), faces
>a few compile problems. Eventually they are GRASS code
>related?
>Here the needed info, I have no idea about this. Due to
>this these modules are not included in the binary package.
>Markus
>Reading specs from /usr/local/lib/gcc-lib/sparc-sun-solaris2.8/3.0.2/specs
>Configured with: ../configure --with-as=/usr/local/bin/as
>+--with-ld=/usr/local/bin/ld --enable-libgcj
>Thread model: posix
>gcc version 3.0.2
>   SRC     = /sd5/sw2001/grass/grass5.0.0pre3/src
>   CMD     = /sd5/sw2001/grass/grass5.0.0pre3/src/CMD
>   UNUSED  = /sd5/sw2001/grass/grass5.0.0pre3/unused
>   HEADER  = head.sparc-sun-solaris2.8
>   ARCH    = sparc-sun-solaris2.8
>   GISBASE = /sd5/sw2001/grass/grass5.0.0pre3/dist.sparc-sun-solaris2.8
>   VERSION = 5.0.0pre3 January 2002
>/sd5/sw2001/grass/grass5.0.0pre3/src/display/d.histogram
>   make -f OBJ.sparc-sun-solaris2.8/make.rules
>/usr/local/bin/gmake5 -all
>/sd5/sw2001/grass/grass5.0.0pre3/src/display/d.histogram/cmd
>make[1]: Entering directory `/sd5/sw2001/grass/grass5.0.0pre3/src/display/d.histogram/cmd'
>gcc -I/sd5/sw2001/grass/grass5.0.0pre3/src/include -g -O2     -c draw_slice.c -o OBJ.sparc-sun-solaris2.8/draw_slice.o
>draw_slice.c: In function `draw_slice':
>draw_slice.c:106: Internal compiler error in change_address, at emit-rtl.c:1635
>Please submit a full bug report,
>with preprocessed source if appropriate.
>See <URL:http://www.gnu.org/software/gcc/bugs.html> for instructions.
>make[1]: *** [OBJ.sparc-sun-solaris2.8/draw_slice.o] Error 1
>make[1]: Leaving directory `/sd5/sw2001/grass/grass5.0.0pre3/src/display/d.histogram/cmd'
>make: *** [all] Error 1
>/sd5/sw2001/grass/grass5.0.0pre3/src/mapdev/v.out.moss
>gcc -I/sd5/sw2001/grass/grass5.0.0pre3/src/include -g -O2     -c area_to_moss.c -o OBJ.sparc-sun-solaris2.8/area_to_moss.o
>area_to_moss.c: In function `area_to_moss':
>area_to_moss.c:144: Internal compiler error in change_address, at emit-rtl.c:1635
>make: *** [OBJ.sparc-sun-solaris2.8/area_to_moss.o] Error 1
>/sd5/sw2001/grass/grass5.0.0pre3/src/raster/r.slope.aspect
>/sd5/sw2001/grass/grass5.0.0pre3/src/raster/r.slope.aspect/cmd
>make[1]: Entering directory `/sd5/sw2001/grass/grass5.0.0pre3/src/raster/r.slope.aspect/cmd'
>gcc -I/sd5/sw2001/grass/grass5.0.0pre3/src/include -g -O2     -c main.c -o OBJ.sparc-sun-solaris2.8/main.o
>main.c: In function `main':
>main.c:1303: Internal compiler error in change_address, at emit-rtl.c:1635
>make[1]: *** [OBJ.sparc-sun-solaris2.8/main.o] Error 1
>make[1]: Leaving directory `/sd5/sw2001/grass/grass5.0.0pre3/src/raster/r.slope.aspect/cmd'
>/sd5/sw2001/grass/grass5.0.0pre3/src.contrib/CERL/raster/r.hydro.CASC2D
>gcc -I/sd5/sw2001/grass/grass5.0.0pre3/src/include -g -O2     -c CASC2D.c -o OBJ.sparc-sun-solaris2.8/CASC2D.o
>CASC2D.c: In function `main':
>CASC2D.c:2995: Internal compiler error in change_address, at emit-rtl.c:1635
>make: *** [OBJ.sparc-sun-solaris2.8/CASC2D.o] Error 1
>/sd5/sw2001/grass/grass5.0.0pre3/src.contrib/NPS/r.out.elas
>main.c:815: Internal compiler error in change_address, at emit-rtl.c:1635
>make: *** [OBJ.sparc-sun-solaris2.8/main.o] Error 1
Palle Haastrup, M.Sc.,Ph.D., MBA
Deputy Head of the Inland and Marine Waters Unit
Institute for Environment and Sustainability
European Commission, Joint Research Centre Ispra
Via E. Fermi, 1, TP 361
21020 Ispra (VA), Italy
Tlf +39 0332 789083, Fax: +39 0332 785807,
Secretary +39 0332 789588
