[GRASS5] Another question on the projection transform
zhang ji
zsfunl at yahoo.com
Thu Jan 24 23:49:36 EST 2002
Hi all,
I have another question on the projection transform.
Does the function in m.proj can be accessed throught
the libgis.a? I mean does there existing the common
API in the grass library which can be directly used
to do some projection transform, for example, i can
specify what the input projection ,input lat/long and
the output projection with the ellipsoids, and the
function can return the output northing/easting?
Thanks,
shifeng
__________________________________________________
Do You Yahoo!?
Great stuff seeking new owners in Yahoo! Auctions!
http://auctions.yahoo.com
