[GRASS5] configure goof?
Glynn Clements
glynn.clements at virgin.net
Sat Jan 26 20:37:36 EST 2002
David D Gray wrote:
> This is picking up Tcl/Tk for TkStep, an old version I still require in
> /usr/local/*. I tried to configure as you can see that it would pick up
> the correct 8.3 libs in /usr/* (I actually have 6 Tcl versions scattered
> about). Then I noticed that this only appends the include and lib
> directories specified. If that is the case, it seems wrong to me: the
> `--with-tcl-incudes' should specify where to look, or at least prepend
> the specified directory. I notice the tiff libs are searched the same
> way, perhaps all search paths are specified this way. If so, can they
> all be changed?
I've fixed the configure checks.
Glynn Clements <glynn.clements at virgin.net>
