[GRASS5] Re: [GRASSweb-list]GRASS-5.0-pre5 with Postgres
Bernhard Reiter
bernhard at intevation.de
Tue Jul 2 05:04:21 EDT 2002
Karl,
this is usually a question for the grass5 development list.
You should give details about the location of the postgres
headers and the results in config.log.
Bernhard
On Mon, Jul 01, 2002 at 06:20:48PM +0200, Karl Broich wrote:
> I tried to build GRASS-5.0-pre5 on SuSe 7.3. If I switch off Postgres using
> ./configure --with-postgres=no
> everthing is created properly. But I intend to try Postgres support :-<
> Postgres installation seems to be ok. I searched for the postgres-header
> files and found them. But configure do not find those files.
> Note: I just installed Postgres. I did not setup a database yet.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020702/19e50afb/attachment.bin
