[GRASS5] Re: intersect sites with polygons?
Radim Blazek blazek at itc.it
Wed Jul 3 05:46:15 EDT 2002
On Wednesday 03 July 2002 06:34 am, Glynn Clements wrote:
> Dots are very common, probably more common than underscore or dash
> (minus). I suggest choosing a character which has meaning to the shell
> (e.g. "$"), as people tend to avoid using map names which require
> quoting.
Can scanner recognize more combinations separated by one char?:
(I think so because type is char, and cat is number)
map
map$lp
map$2,5
map$lp$2,5
Category ranges (25-35) should be also alloved, preferably without
necessity of quotes:
map$lp$3,7,25-30,120
Radim
