[GRASS5] trouble in getting grass51 from cvs
Moritz Lennert lennert.moritz at edpnet.be
Thu Jul 4 05:02:45 EDT 2002
I'm trying to checkout the grass51 tree through my read/write access from the intevation server, but I get the following error message:
$ cvs -z3 checkout grass51
ssh: connect to address 63.209.80.227 port 2402: Connection refused
cvs [checkout aborted]: end of file from server (consult above messages if any)
My env variables are set as follows:
$ echo $CVSROOT
:ext:moritz at intevation.de:/grassrepository
$echo $CVS_RSH
/home/mlennert/.ssh2402
Can anyone tell me what I'm doing wrong ? (with the same variable settings I can update the grass, web, and grass_doc modules without any problems)
Moritz
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020704/3134af5f/attachment.bin
