[GRASS5] trouble in getting grass51 from cvs
Bernhard Reiter
bernhard at intevation.de
Fri Jul 5 09:34:45 EDT 2002
Did you set the $CVSROOT variable correctly?
On the other hand, there might have been some DNS or network
problems yesterday.
On Thu, Jul 04, 2002 at 01:35:06PM +0200, Moritz Lennert wrote:
> > > What is really bizarre is that when I type, for example:
> > > cvs -z3 co grass_doc
> > > it works perfectly
> > > but cvs -z3 co grass51
> > > gives me the funny message with the weird IP address.
> > Look at grass51/CVS/Root. the file must contains the
> > same contents than $CVSROOT. If not, this can be the problem
> I don't have grass51, yet, that's why I want to check it out ;-)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020705/5d0c1db3/attachment.bin
