[GRASS5] compiling grass51
Moritz Lennert
lennert.moritz at edpnet.be
Mon Jul 8 05:03:52 EDT 2002
Obviously my fault: I used a relative instead of a full reference to the GRASS5.0 source.
Sorry,
Moritz
On Mon, Jul 08, 2002 at 09:24:45AM +0200, Radim Blazek wrote:
> On Friday 05 July 2002 05:56 pm, Moritz Lennert wrote:
> > Hi,
> > Trying to compile grass51, I get:
> > $ make
> > make[1]: Entering directory `/home/mlennert/GRASSCVS/grass51/lib'
> > bitmap
> > make[2]: Entering directory `/home/mlennert/GRASSCVS/grass51/lib/bitmap'
> > make[2]: *** Pas de règle pour fabriquer la cible `bitmap.c', nécessaire
> > pour `OBJ.i586-pc-linux-gnu/bitmap.o'. Arrêt. make[2]: Leaving directory
> > `/home/mlennert/GRASSCVS/grass51/lib/bitmap' make[1]: *** [subdirs] Erreur
> > 1
> > make[1]: Leaving directory `/home/mlennert/GRASSCVS/grass51/lib'
> > make: *** [default] Erreur 1
> > I'm not sufficiently confortable with make to know how to solve this in the
> > Makefile.
> > Moritz
> Do you have grass51/grass50 mixture (make mix)?
> See 'INSTALL'.
> Radim
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020708/5fd2fe63/attachment.bin
