[GRASS5] Critical bugs for Release?
Radim Blazek blazek at itc.it
Wed Jul 17 07:17:14 EDT 2002
On Tuesday 16 July 2002 10:08 pm, Bernhard Reiter wrote:
> > #1136	detailed view of vector maps doesn't work
> > The reporter followed up with "v.spag then v.support seem to fix
> > this", so presumably this should be closed?
> I've lowered priority to 30.
> I'm not entirely sure how this is supposed to work.
> Just running v.support once should be enough, shouldn't it?
Was realy bug in d.vect, small (overlap < 75%) areas were never
plotted on level 1. I fixed in HEAD branch. I don't know if it is
release critical.
Radim
