[GRASS5] [bug #1201] (grass) can't remove base map from reclassed map
Markus Neteler via RT
grass-bugs at intevation.de
Wed Jul 24 08:29:17 EDT 2002
I also consider this to be a bug which sometimes appears.
On my machine 4-5 times, see also:
http://intevation.de/rt/webrt?serial_num=837&display=History
http://intevation.de/rt/webrt?serial_num=863&display=History
I don't think that it is a user error because it is pretty
hard to use g.remove in a wrong way.
Markus
-------------------------------------------- Managed by Request Tracker
