[GRASS5] [bug #1210] (grass) quering r.cross result crashes
Glynn Clements glynn.clements at virgin.net
Fri Jul 26 21:23:56 EDT 2002
Otto Dassau wrote:
> I solved my problem partly using
> r.null map=crosstest setnull=0
> but I do not understand why this works. The problem areas were already
> NULL <no data> in both initial maps, so why not in the result map after
> using r.cross?
r.cross hasn't been updated to understand null values yet.
The actual data is read using G_get_map_row(), which automatically
converts nulls to zeroes. However, the category information will refer
to null rather than zero (or maybe both null and zero).
Glynn Clements <glynn.clements at virgin.net>
