[GRASS5] [rpm spec for grass]
Eric G. Miller
egm2 at jps.net
Sun Jun 2 19:04:28 EDT 2002
On Sun, Jun 02, 2002 at 11:34:49PM +0200, Sergiusz Pawlowicz wrote:
> Hello, Arkadiusz Mi?kiewicz & Artur Wróblewski wrote spec
> file for Grass5-pre4, available from:
> http://ibiblio.org/ser/cvs/index.cgi/*checkout*/SPECS/grass.spec?rev=HEAD&content-type=text/plain
> It is almost finished, but there is a problem with
> iterferention with ImageMagick package, Grass uses the
> same commands "display" & "import". Maybe we can change
> these names?
AFAIK, there aren't any "display" or "import" commands in GRASS. There
are categories of commands that do these things, but none named as
"display" or "import". So, what exactly are you referring to?
Eric G. Miller <egm2 at jps.net>
