[GRASS5] GLib?
Radim Blazek
blazek at itc.it
Thu Jun 6 10:51:29 EDT 2002
(Was "Want GNU libavl ?" 6 monts ago
http://grass.itc.it/pipermail/grass5/2002-January/001704.html )
> > > The latest GLib is probably the closest I can think of. It has hashes,
> > > trees, sets, etc... The reason I went with libavl, is it is purportedly
> > > better optimised for the balanced trees, and it's simple to include the
> > > files you need (two in my case).
> > I see... but GLib is at the core of the GNOME programming environment...
> > is it possible to extract only the more general part without having to
> > carry also GNOME dependacies?
> GLIB can be used alone. It is why they made it a separate lib.
> Robert Lagacé, professeur
Can we start to use GLib in grass51?
If yes, how? As is or should we write some wrappers in Grass?
If wrappers, then is anybody here who can do that, I don't
have neither capacity nor knowledges.
If no, what to do instead?
Radim
