[GRASS5] GRASS 5.0.0stable to be released soonish
Bernhard Reiter
bernhard at intevation.de
Tue Jun 11 11:28:52 EDT 2002
On Tue, Jun 11, 2002 at 04:38:03PM +0200, Markus Neteler wrote:
> There are several important
> fixes mentioned. GRASS cannot even installed without at least the
> Makefile fix etc.
We should make these of course.
> > No fundamental changes. Only critical bug fixes.
> > And everybody should have committed them already to the release branch.
> .. which didn't happen...
AFAIK mostly Glynn postponed the checkin of his code changes.
Most of the other changes does not seem to be release critical.
> Also a bugfix from David for v.in.shape is in the queue (he wrote to
> me personally since he is currently no subscriber).
It may be too late for 5.0.0 then...
or is it release critical?
We should be as close to 5.0.0pre4 as we can,
because this was tested a lot.
Any change we make might introduce other bugs.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020611/220ff3eb/attachment.bin
