[GRASS5] [bug #1118] (grass) Grass on Zaurus
Markus Neteler
neteler at itc.it
Fri Jun 14 16:50:23 EDT 2002
On Fri, Jun 14, 2002 at 09:47:53PM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=1118
> Subject: Grass on Zaurus
> Platform: other
> grass obtained from: Other (CDROM etc)
> grass binary for platform: Downloaded precompiled Binaries
> GRASS Version: 5.0pre4
> Trying to install Grass GIS for my Sharp Zaurus using the Ipaq/Linux binary I got from Baylor University
> http://www3.baylor.edu/grass/grass5/binary/ipaq_linux/
> when I use Terminal and try the "ipkg install" command, here's what I get:
> zcat: grass_5.0.0-20020507-1_arm.ipk: invalid compressed data--format violated
> tar: Unexpected EOF in archive
> tar: Error exit delayed from previous errors
This looks like a transmission error, because:
tar tvfz grass_5.0.0-20020507-1_arm.ipk
-rw-rw-r-- root/root 4 2002-05-07 17:06:15 ./debian-binary
-rw-rw-r-- root/root 556483 2002-05-07 17:06:15 ./data.tar.gz
-rw-rw-r-- root/root 522 2002-05-07 17:06:15 ./control.tar.gz
is fine (at least on
http://grass.itc.it/grass5/binary/ipaq_linux/
> zcat: stdin: unexpected end of file
> ipkg_install_file: ERROR unpacking control.tar.gz from grass_5.0.0-20020507-1_arm.ipk
> Thank you in advance for any advice you can provide
You may try again from ITC.
Markus
