[GRASS5] [compiling on two or more processors?]
Glynn Clements
glynn.clements at virgin.net
Sun Jun 16 18:48:43 EDT 2002
Sergiusz Pawlowicz wrote:
> I'm trying to compile Grass5 on machine with two processors:
[snip]
> Why does it fail?
The usual reason why parallel make fails is that one target depends
upon another but doesn't actually specify it as a dependency.
In this case, it looks like something is being built (from the
"do-compile" target) before src/CMD/head/head has been renamed to
src/CMD/head/head.<arch> (in the "pre-compile" target").
Try running "make pre-compile" first, without any "-j" switch, then
run the parallel make once that has completed.
If that doesn't work, it's unlikely to be fixed in 5.0.x. The build
system is intended to be replaced for 5.1.
Glynn Clements <glynn.clements at virgin.net>
