[GRASS5] GRASS 5.0.0stable to be released soonish
Markus Neteler neteler at itc.it
Mon Jun 17 07:52:13 EDT 2002
On Mon, Jun 17, 2002 at 02:19:45AM +0100, Glynn Clements wrote:
> I've merged most of the recent changes into the release branch. A
> summary of the outstanding differences follows.
> The outstanding differences fall into two categories:
> 1. Substantial changes to individual modules; for these, I'd just like
> confirmation that the result is stable enough for inclusion in the
> pre5 release.
> 2. I18N-related changes to key components (GRASS startup, libgis,
> tcltkgrass). For these, I would really like confirmation that building
> without NLS (i.e. no "--with-nls" option) has been tested by as many
> people as possible.
> If any portability issues (e.g. assumptions regarding bash, GNU make,
> Tcl/Tk version, head.<arch> settings etc) have slipped in, the result
> could be completely unusable for some users.
> I'm not concerned about it breaking if --with-nls is used; this *will*
> fail on systems where dgettext() etc are in libintl rather than in
> libc (e.g. Cygwin).
> [Lines beginning with "+" indicate added files or directories; the
> rest are changed files.]
> tcltkgrass I18N (alex)
> +	locale/ru/tcltkgrass/
> 	locale/Gmakefile
> 	src/tcltkgrass/tcltkgrass
> 	src/tcltkgrass/main/gis_set.tcl
> libgis I18N (alex)
> +	locale/ru/LC_MESSAGES/libgis.po
> 	src/libes/gis/Gmakefile
> 	src/libes/gis/*.c
> Startup I18N (alex)
> +	locale/ru/grass_intro.txt
> +	locale/ru/license.txt
> +	src/general/init/license.txt
> 	locale/Gmakefile
> 	src/general/init/Gmakefile
> 	src/general/init/init.sh
> d.text.freetype update (cho): alignment, rotation, command mode
> +	src/display/d.text.freetype/vflib/
> +	src/display/d.text.freetype/test.input
> 	html/html/d.text.freetype.html
> 	src/display/d.text.freetype/Gmakefile
> 	src/display/d.text.freetype/freetypecap
> 	src/display/d.text.freetype/main.c
> d.vect.pg update (alex): -e flag [*]
> 	html/html/d.vect.pg.html
> 	locale/ru/LC_MESSAGES/d.vect.pg.po
> 	src.garden/grass.postgresql/d.vect.pg/dbvect.h
> 	src.garden/grass.postgresql/d.vect.pg/getAllOpts.c
> 	src.garden/grass.postgresql/d.vect.pg/getSopts.c
> 	src.garden/grass.postgresql/d.vect.pg/main.c
> 	src.garden/grass.postgresql/d.vect.pg/runInfxFile.c
> v.to.pg update (alex): -p flag (PostGIS)
> 	locale/ru/LC_MESSAGES/v.to.pg.po
> 	src.garden/grass.postgresql/v.to.pg/dbvect.h
> 	src.garden/grass.postgresql/v.to.pg/getAllOpts.c
> 	src.garden/grass.postgresql/v.to.pg/getSopts.c
> 	src.garden/grass.postgresql/v.to.pg/main.c
> 	src.garden/grass.postgresql/v.to.pg/plotCat.c
> 	src.garden/grass.postgresql/v.to.pg/runInfxFile.c
> v.in.shape update (david)
> 	html/html/v.in.shape.html
> 	src/tcltkgrass/module/v.in.shape
> 	src/mapdev/v.in.shape/basename.c
> 	src/mapdev/v.in.shape/lines.c
> 	src/mapdev/v.in.shape/main.c
> 	src/mapdev/v.in.shape/polygon.c
> 	src/mapdev/v.in.shape/vmap_import.c
This v.in.shape fix I suggest to include since David was categorizing
it as important bugfix.
Markus
