[GRASS5] IRIX 6.2 Compilation Report
Paul Kelly
paul-grass at stjohnspoint.co.uk
Tue Jun 18 10:54:55 EDT 2002
This isn't a thorough report as I didn't enable everything, but I brought
in a copy of the release branch from CVS this morning so it should be the
same content as GRASS 5.0.0pre5 will have. Got the following errors:
GRASS GIS compilation log
Start of compilation: Tue Jun 18 14:02:53 BST 2002
Errors:
Compilation error in module: src/libes/dbmi/clients (ignored)
Compilation error in module: src/display/d.db (ignored)
Compilation error in module: src/display/d.what.db (ignored)
Compilation error in module: src/display/d.what.vect (ignored)
Compilation error in module: src/mapdev/v.db.reclass (ignored)
Compilation error in module: src/mapdev/v.in.mif (ignored)
Compilation error in module: src/mapdev/v.in.shape (ignored)
Compilation error in module: src/mapdev/v.out.shape (ignored)
Compilation error in module: src/mapdev/v.to.db (ignored)
Compilation error in module: src/raster/r.in.shape (ignored)
Compilation error in module: src/sites/s.in.dbf (ignored)
Compilation error in module: src.contrib/GMSL/NVIZ2.2 (ignored)
All above contain references to snprintf(), solved by adding a 3rd party
snprintf library to the end of the list in the appropriate Gmakefiles.
Compilation error in module: src/raster/r.sun (ignored)
Fixed by making the following change to src/raster/r.sun/main.c:
1426,1427c1426,1427
< G_fatal_error("Can't get projection info of current
< please set latitude via 'lat' or 'latin'
option!");
> "please set latitude via 'lat' or 'latin'
option!");
Compilation error in module: src/display/d.text.freetype (ignored)
Couldn't fix this one; the error is
/indigo-disk2/grass/grass/src/display/d.text.freetype
make -f OBJ.mips-sgi-irix6.2/make.rules
cc -I/indigo-disk2/grass/grass/src/include -g
-I/indigo-disk2/grass/doom.ee.qub.ac.uk/include
-I/indigo-disk2/grass/freetype-2.1.0/include -c main.c -o
OBJ.mips-sgi-irix6.2/main.o
cfe: Error: main.c, line 47: Syntax Error
static FT_Library library;
cfe: Error: main.c, line 47: Empty declaration specifiers
cfe: Error: main.c, line 48: Syntax Error
static FT_Face face;
cfe: Error: main.c, line 48: Empty declaration specifiers
make: *** [OBJ.mips-sgi-irix6.2/main.o] Error 1
End of compilation: Tue Jun 18 15:18:12 BST 2002
DONE generating GRASS GIS binary code
N.B. I didn't try compiling everything; here are the with / without
configure options I used:
--with-dbm=no
--with-odbc=no
--with-postgres=no
--with-fftw=no
--with-motif=yes
--with-freetype=yes
