[GRASS5] [bug #1124] (grass) v.in.sdts segmentation fault on illegal tag
Request Tracker
grass-bugs at intevation.de
Wed Jun 19 14:29:44 EDT 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1124
Subject: v.in.sdts segmentation fault on illegal tag
Platform: GNU/Linux/i386
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: GRASS 5.0.0pre4 (May 2002)
I updated the Grass5pre4 source from CVS on June 18, 2002. I am running
SuSE 8.0 on PII 350 mHz system with 512 mb ram and a 20 gb hard disk. Upon
trying to read an SDTS data file for Caples Lake, Cailfornia that should
contain vector lines for contour data, I get an error.
v.in.sdts -i yields the following. v.in.sdts does not process the LE module
as part of this process.
v.in.sdts output -----------------
Processing CATD module
Processing STAT module
Processing IDEN module
Processing XREF module
Processing IREF module
INFORMATION ABOUT THE SDTS DATA SET
Identification module: 9760IDEN.DDF
Standard identification: SPATIAL DATA TRANSFER STANDARD
Standard version: 1998 JUNE 9
Standard documentation reference: ANSI NCITS 320-1998
Profile identification: SRPE: SDTS RASTER PROFILE and EXTENSIONS
Profile documentation reference: Federal Geographic Data Committee
FGDC-STD-002.5
Profile version: 1998
Title: CAPLES LAKE, CA-24000
Data ID: LAT:: 38 37 30.0000 N LONG:: -120 0
0.0000 W SCALE:: 24000
Data structure: DEM
Map date: 1998
Data set creation date: 2001823
External Spatial Reference module: 9760XREF.DDF
Reference System name: UTM
Horizontal Datum: NAS
Zone Number: 10
Spatial Domain module: 9760SPDM.DDF
Spatial Domain type: RING
Domain Spatial Address X: 926232626.000000
Domain Spatial Address Y: 875706168.000000
Domain Spatial Address X: 926169400.000000
Domain Spatial Address Y: 875706674.000000
Domain Spatial Address X: 926298167.000000
Domain Spatial Address Y: 875706675.000000
Domain Spatial Address X: 926298417.000000
Domain Spatial Address Y: 875706169.000000
MAP: CAPLES LAKE, CA
THEME: ELEVATION
MANIFOLD: DEM1
BOUNDARY:
MIN_X MIN_Y MAX_X MAX_Y
-1073746520.000000 1074487268.000000 134739968.000000
1073790160.000000
end ----------------------------------------------------------
Upon attempting to read in the data, I get a message:
Processing LE module: 9760LDEF.DDF Illegal Tag = LDEF
Then a string of illegal tag = LDEF messages, terminating in a segmentation
fault.
Thanks,
-------------------------------------------- Managed by Request Tracker
