[GRASS5] [bug #1127] (grass) crash on startup unless Init.sh hand-modified
Hal Mueller hal at mobilegeographics.com
Thu Jun 20 13:50:13 EDT 2002
Just so this gets into the archives--
All my libraries are in "standard" places (/usr/lib, /usr/local/lib).
However, the nonstandard thing I was doing (which was causing the
launch failure) was not having a setting for LD_LIBRARY_PATH at all
(which I had done to work around another vendor's installation
quirks).  So my proposed solution was way off base.  Once I added a
LD_LIBRARY_PATH the default Init.sh works fine.
H
