[GRASS5] Re: [GRASSLIST:3982] Re: GLIBC_2.2 not found
    Glynn Clements
    glynn.clements at virgin.net
    Fri Jun 28 18:22:43 EDT 2002
[CC'd to GRASS5]
Steve Kimball wrote:
> I'm also runnig Red Hat 6.2 and got
>   r.in.ascii: /lib/libc.so.6: version 'GLIBC_2.2` not found (required
> for r.in.ascii)
You would either have to install glibc 2.2 (RH6.2 uses glibc 2.1), or
obtain a binary package which was intended for RH6.2 (or another
distribution which uses glibc 2.1).
Programs which were compiled for RH7.x will almost never work on
RH6.x, due to the different version of glibc.
Hmm. If this is the package from grass.itc.it, i.e.
http://grass.itc.it/grass5/binary/linux/grass5.0.0pre3_i686-pc-linux-gnu_bin.tar.gz
then the README (which claims that it requires glibc 2.1) is
incorrect.
Glynn Clements <glynn.clements at virgin.net>
