[GRASS5] successful launch of Envisat, request on remote sensing modules
wolfluck at mweb.co.za
Fri Mar 1 05:54:01 EST 2002
Dear development team
Have you heard the latest news? Envisat, Europe's largest remote sensing
satellite was launched successfully at 02:00 this morning on an Ariane 5
rocket. The first images should soon be made available to the academic
community.
Another matter. How is r.in.hdf coming along for HDF 5 import and a function
to orthorectify Landsat 7 ETM+ imagery? Markus mentioned that someone was
working on it.
What atmospheric correction models have been implemented into GRASS ? I have
the source code for a 6S model, which I might be able to port to GRASS, and
the implementation of the COST model from Chavez, 1996, should not be to
difficult.
Then has anyone ever done a Minnaert topographic (solar) correction in
GRASS? I presume that r.linear.regression is the appropriate command for the
regression analysis necessary for this rectification process. Unfortunately
it needs ASCII files in a specific format as input. How can the
preclassified image be exported to this? Isn't it possible to do a
regression analysis with raster files directly within for instance mapcalc?
Greetings Wolfgang
Wolfgang Lück
Infoterra GmbH
88039 Friedrichshafen
Germany
Tel: + 49 7545 8 2150
Fax: + 49 7545 8 5650
email: Wolfgang.Lueck at astrium-space.com
This message was sent using M-Web Airmail
JUST LIKE THAT
http://airmail.mweb.co.za/
