[GRASS5] [bug #942] (grass) prequisites for compiling
Markus Neteler
neteler at itc.it
Mon Mar 4 12:26:18 EST 2002
Hi Dietrich,
On Mon, Mar 04, 2002 at 06:18:54PM +0100, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=942
> Subject: prequisites for compiling
> Platform: Linux/Intel
> Linux distro: SuSe
> linux cpu: Intel (i486, i586, pentium ...)
> Xwindows version: Xfree 4.0.x
> Xwindows manager: KDE 1.x
> TclTk version: tcl/tk 8.3
> grass downloaded at: CVS Server, Germany
> grass binary for platform: I compiled the sources myself
> grass sources source: yes, I am using the latest GRASS from CVS
> c compiler name: gcc
> Hello,
> I wanted to try out the 3D-vektors of Grass5.1, three day later i still
> compiling, and i would like to report following problems/bugs.
> 1.) The first thing is that it is not clear to see if you download grass51
> and read the install manual, that you need for compiling the
> experimental_CSV snapshot of GRASS5, and not the other sources. Somewhere
> is was written, and it took me one day to get that out.
> If it is really the case that it is needed the experimental_CVS version,
> please write that in the INSTALL file which comes along with Grass5.1.
if you look there:
"--with-grass50 must be full path to MAIN branch (not release) of
grass 5.0"
it says: 'not release'. But I can write
"--with-grass50 must be full path to MAIN (=experimental) branch
(not release) of grass 5.0"
into that file.
[more tomorrow]
Markus
