[winGRASS] Re: [GRASS5] winGRASS package routine
Markus Neteler
neteler at itc.it
Tue Mar 5 05:54:52 EST 2002
On Mon, Mar 04, 2002 at 03:21:43PM +0000, Glynn Clements wrote:
> Markus Neteler wrote:
> > I have recently packages a winGRASS version with generic driver.
> > There is a problem in the package routine as the "libG11.dll"
> > is not packed into the .tar.gz (libG11.dll is stored in /bin).
> > We have two options (or one only?):
> > 1) extend the package and also the install routines to handle
> > /bin/libG11.dll
> > 2) store libG11.dll in the driver/ directory and handle the
> > path to the DLL (no idea how to do that on windows).
> > Personally I prefer the 2) option as less changes are required.
> IIRC, windows looks for DLLs in the current directory, %PATH%,
> %WINDIR% and %SYSDIR%, so you would have to either:
> a) add the directory which contains the DLL to the path, or
> b) store the DLL in a directory which will be in the path anyway, e.g.
> $GISBASE/bin.
> I think that b) is preferable.
I have applied a related change. Now libG11.dll goes into
$GISBASE/bin.
It may be a good idea to delete
/bin/libG11.dll
after successful compilation of the latest version to avoid
version confusions.
Markus
