[GRASS5] Re: Solaris2.6 Binaries
Andreas Lange
Andreas.Lange at Rhein-Main.de
Mon Mar 11 09:46:51 EST 2002
Markus Neteler wrote:
> Hi developers,
> (cc Nicolas)
> On Mon, Mar 11, 2002 at 12:08:49PM +0200, Nicolas Boretos wrote:
> > Hi,
> > It's been awhile since I've used grass. I wonder if there is a current
> > 5.0 pre3 binary
> > for sperc/solaris2.6, or if the solaris8 bins work?
> > Thanx in advance, and sorry for the unsolicited mail (I have checked all
> > the sites so far...)
> > nicolas boretos
> does anyone know if solaris8 binaries are downward compliant to
> sparc/solaris2.6 (both SUN)?
Markus, Nicolas,
i can't say if the sol8 bins will run on solaris 2.6. But my experience
is that binaries from solaris 8 run under solaris 7, so you might simply
install the binary and check if it works. I see no other way than
trying.
If i remember correctly the pkg-package does not check for the os
version. So installation should be no problem. May be you can not get
the latest tcl/tk 8.3 for solaris 2.6.
Please do not forget to tell us if it works. If not i can change the
pre-inst script to check for the os version.
But upgrading from 2.6 to sol 7 (or 8) should be not that much of a
problem now.
HTH,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
url: http://mitglied.lycos.de/AndreasLange
mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
