[GRASS5] Re: Grass clones
Markus Neteler
neteler at itc.it
Thu Mar 14 11:36:24 EST 2002
Hi Giulio, hi Ettore,
(cc grass5 list)
thanks a lot for your efforts! With this mail I try to get
more people interested in that story... hi developers!
Developers: Prof. Antoniol was so kind to start a first try on
GRASS clone detection. A clone is considered as a piece of code
which is very similar to another piece of code (poor man's definition).
If a clone appears several times, it should become a library
function to simplify the maintenance. In fact detection of clones
is not so easy. You may, for an introduction, read this paper:
Paolo Tonella, ITC-irst: "An Introduction to Clone Detection"
http://mpa.itc.it/grass2001/tonella2001_clones.ps
I do not re-sent the new GRASS clones analysis here due to bandwidth
limitations, but I have put this preliminary analysis online:
http://mpa.itc.it/markus/tmp/grass.cln
(550k, ASCII)
Please read further on Giulio Antoniol's mail below.
Giulio: let's wait for some comments... I'll forward if needed.
Thanks!
Markus
On Thu, Mar 14, 2002 at 04:28:49PM +0100, antoniol wrote:
> Hi Markus
> sorry for the delay we are really busy this time ....
> here the first shot ... I used the:
> grass5src_cvs_snapshot_experimentalMar_8_2002.tar.gz
> Clones were extracted at the function level, i.e., the finest grain unit
> was considered the
> C functions (we did not search clones between compount statments).
> Out of about 20000 functions there are about 16777 over 5 LOC with
> something like 5000 clones.
> Clones were computed in the most stringent way (exact matching).
> when you see:
> 15402 15317 12498 5391
> /ponza2/grass/src.contrib/GMSL/ogl3d_linux/gsf/open.c reverse 163 168
> /ponza2/grass/src.contrib/GMSL/ogl3d_linux/gsf/gsd_img.c reverse 170 175
> /ponza2/grass/src.contrib/CERL/SGI/libimage/open.c reverse 163 168
> /ponza2/grass/src/libes/libimage/open.c reverse 214 219
> means that the functions reverse in the 4 files open.c, gsd_img.c,
> open.c (SGI) and open.c (libimage)
> are clones; the function body starts at loc 163 ends at 168 etc.
> About 2 hours were required to parse the code and produce the result. Our
> C parser is not very precise instead it is extremely robust thus there may
> be functions missed in the computation.
> Please consider this the very preliminary result. I did the work in
> cooperation with Ettore Merlo who wrote the clone recognizer. He told me
> he will produce a finer grained classification plus a color html
> visualization.
> We just need to find another couple of hours to process the data.
> In the meantime, I take the liberty to suggest that we cooperate following
> the clone documentation and refactoring process, we are basically very
> interested to obtain data from the GRASS developers on clone effects. For
> example, since you have a bug tracking tool, we may correlate clone with
> removed bugs: how many time a removed bug impacted a clone, and were
> clones de-bugged?
> Are there cases where automatic refactoring is possible? Or, can we use
> clone information to cluster functions into libraries?
> Let us know, ciao
> Giulio
