[GRASS5] The status of 5.0
Helena Mitasova
hmitaso at unity.ncsu.edu
Thu Mar 21 11:40:40 EST 2002
Michel Wurtz wrote:
> Roger Miller wrote:
> > 5. v.out.shape exported only closed polygons. I found no way around that
> > behavior. Is that inherent in shape files?
> Did you try v.out.e00 (and then Import71, the free ESRI translator
> from e00 to coverage, so Arcview can read the data) ? It should work
> for closed polygons _and_ any kind of line...
> But I agree with Helena : vector in Grass4.0 and 5.0 are not very usefull,
> mainly because the attribute sheme is very cheap... You cannot really have
> a vector GIS without an associated database (or at least a kind of).
> BTW, the site management is also ugly : the grass inner format is ascii and
> there is a lot of pretty complicated functions to do apparently nothing else
> than moving strings from one ascii file to another. Here also, a database
> seems to be a better solution (more attribute's types, direct binary storage,
> use of attributes values to parametrize symbols, etc...). To do in 5.1 ?
As far as I remember there is a consensus to handle sites within a GRASS5.1
vector format, which should handle all that you are mentioning here. So I would
just encourage
everybody to get grass5.1 to get some feel for it and maybe it would be good
time
to start moving all GRASS to GRASS5.1 - as I understand it a reorganization
of the code is planned so I assume that it would be a substantial effort.
Given my previous experiences with moving sites to vectors the ascii site format
will be
around for a while, but the development should really focus on GRASS5.1
concepts.
Helena
> Michel WURTZ - DIG - Maison de la télédétection
> 500, rue J.F. Breton
> 34093 MONTPELLIER Cedex 5
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
