[GRASS5] [bug #976] (grass) v.transform would not read that header of files
Request Tracker
grass-bugs at intevation.de
Fri Mar 22 03:17:35 EST 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=976
Subject: v.transform would not read that header of files
Roger Miller /Carl Worth wrote
> > 10. v.out.ascii gave me a header with a blank line imbedded in it, and
> > v.transform would not read that header.
> As far as I used v.transform, it doesn't need a header. From
> http://grass.itc.it/gdp/html_grass5/html/v.transform.html
> "An example of the pointsfile file:
I just ran into the same bug. It's not in the pointsfile, but rather
that v.out.ascii makes a blanks line in the header of the generated
vector ascii file. Then, v.transform aborts when it encounters the
blank line.
I don't know which module is buggy here.
-------------------------------------------- Managed by Request Tracker
