[GRASS5] The status of 5.0
Glynn Clements
glynn.clements at virgin.net
Fri Mar 22 09:26:06 EST 2002
Bernhard Reiter wrote:
> > > > (possibly renaming
> > > > the tag so that changes aren't committed to it inadvertently).
> > > We have to slap developers on the wrist for committing changes to
> > > this branch!!! They will have to put it in the right branch again.
> > I've renamed the tag, so any attempts to checkout, update or commit
> > using the releasebranch_11_april_2001_5_0_0 tag should fail.
> Is this the right way?
> People should be able the get versions from the branch for historical
> purposes. What is the new name?
releasebranch_11_april_2001_5_0_0_DEAD
In any case, a branch tag doesn't refer to a fixed point in time, but
to the most recent version on that branch. Specific snapshots can be
obtained using the non-branch tags (pre3 etc).
Also, it is possible to obtain a snapshot of the head as of a specific
date using -D. Unfortunately, it isn't possible to combine -r and -D
to obtain a snapshot of a branch.
> > 5. I18N/L10N of grass.postgresql/*, s.surf.rst (alex)
> I'm not entirely convinced that we should put this in the GRASS5.0 tree.
AFAICT, undefining HAVE_LIBINTL_H will completely disable the I18N
support. Maybe this should be done for building binary distributions.
Glynn Clements <glynn.clements at virgin.net>
