[GRASS5] The status of 5.0
Glynn Clements
glynn.clements at virgin.net
Mon Mar 25 06:24:09 EST 2002
rgrmill at rt66.com wrote:
> 2) As I wrote a couple months ago, I have a "resource manager" that
> associates each monitor with a different geographic window and different
> gis environment, including mapset and location. There is associated
> with that capability a module that allows the user to change the current
> mapset and location without leaving grass and (hopefully) without
> bothering anyone else working at the same time. This allows one user to
> work in multiple locations/mapsets at the same time. The manager also
> specifies certain types of system behavior; monitors are automatically
> erased when their region is changed and removed when the user exits
> grass. The manager offers the kind of persistence and event-driven
> behavior that we sometimes talk about needing for future development.
> The manager, in one form or another, provides a lot of opportunities for
> future development.
> I still have one bug left to work out. When it's done I'll submit a
> description of the program and the working source code as a proposal.
> It requires changes to put_window.c, get_window.c, env.c and d.mon.
One of the main obstacles to switching location/mapset on the fly is
the number of scripts[1] which reference $GISDBASE, $LOCATION_NAME,
$MAPSET and/or $LOCATION directly.
Currently, these are set in Init.sh using "eval `g.gisenv`". There
isn't any way to subsequently change them using an external command;
using "eval" is inconvenient, and shell aliases/functions are messy
(non-portable, aren't inherited by scripts).
Shell scripts ought to be calling e.g. "eval `g.gisenv`" themselves to
obtain the current settings from $GISRC.
[1] AFAICT, I've fixed all of the C programs which accessed these
variables via getenv().
Glynn Clements <glynn.clements at virgin.net>
