[GRASS5] [bug #992] (grass) g.region Vask problem in lat/long
Markus Neteler
neteler at itc.it
Thu Mar 28 02:59:49 EST 2002
On Wed, Mar 27, 2002 at 10:50:50PM +0000, Glynn Clements wrote:
> > > Markus Neteler wrote:
> > > > Now starting g.region, selecting menu 1:
> > > > V_ask error: Length out of bounds in call to V_const <- this warning appears for 3 sec
> > > > The west value makes me unhappy. Looks like a rounding problem somewhere.
> > > Well, floating point can't represent exactly fractions where the
> > > denominator isn't a power of two, so rounding errors will occur.
> > Mhhh, but I was demanding rounded coordinates with
> > g.region res=0:00:30 -a
> > earlier. The DEFAULT_WIND contains a round West, only inside g.region
> > it appears strange (means: should be everywhere the same value).
I am sorry, Glynn - today I could only partially reproduce the problem.
It seems I was overlooking something yesterday.
g.region -dp
projection: 3 (Latitude-Longitude)
zone: 0
datum: WGS84
ellipsoid: WGS84
north: 8:59:45S
south: 29:00:15S
west: 15:59:59.999982E
east: 34:00:29.999982E
nsres: 0:00:30
ewres: 0:00:30
rows: 2401
cols: 2161
Now the error
"V_ask error: Length out of bounds in call to V_const"
is explanable.
I generated this location from GLOBE DEM30 (user defined window)
automatically with r.in.gdal (it reads GLOBE DEM30 directly),
therefore these strange west/east boundaries:
gdalinfo botswana.bil
Driver: EHdr/ESRI .hdr Labelled
Size is 2160, 1920
Coordinate System is '
Origin = (16.000000,-13.000000)
Pixel Size = (0.008333,-0.008333)
Corner Coordinates:
Upper Left ( 16.0000000, -13.0000000)
Lower Left ( 16.0000000, -28.9999936)
Upper Right ( 33.9999928, -13.0000000)
Lower Right ( 33.9999928, -28.9999936)
Center ( 24.9999964, -20.9999968)
Band 1 Block=2160x1 Type=Int16, ColorInterp=Undefined
NoData Value=-500
> Well, GRASS doesn't use DMS internally; the DMS -> FP -> DMS
> conversions could easily introduce rounding error. Particularly if
> something is multiplying a rounded representation of one second by 30.
> > > G_lon_format() (which generates the string in question) doesn't use
> > > any specific precision, so you get the standard behaviour of "%f",
> > > which is 6 digits after the point.
> > > But how many digits should it use? Are whole seconds sufficiently
> > > accurate? Unless you require accuracy better than thousandths of a
> > > second, the argument should be converted to seconds and integer
> > > arithmetic used.
> > Eventually yes. At least the overwriting (see RT followup) isn't nice.
> I slighly change the report:
> The field of default region in the g.region menu is too long and writing
> into the current region. If there are no objections we should limit the
> field length in
> src/libes/gis/edit_cellhd.c
> What should it be changed to? To whatever space is currently
> available?
I think so. Or we have to use two lines
default_west
| current_west
In this case default_west may keep its original length. I am not
sure if that is a good idea.
> This would be better done in G_{lat,lon}_format(); using a precision
> specifier (e.g. "%.2f") will round the result, so that e.g.
> "59.999999" -> "60.00", while truncating the string within
> G_edit_cellhd() would, er, truncate it, so "59.999999" -> "59.99".
> But G_{lat,lon}_format() are used elsewhere, and other uses might
> warrant greater precision. Ideally the formatting functions should
> allow the precision to be specified, but that has compatibility
> implications.
> Ultimately, there are two problems here. One is that the error is
> being introduced in the first place, the other is that G_edit_cellhd()
> only copes with certain easting/northing values.
If still needed, I can put the entire location somewhere. Let me know
(46MB uncompressed).
Markus
