[GRASS5] A naive opinion on how grass *should* work
Glynn Clements
glynn.clements at virgin.net
Fri May 3 03:07:52 EDT 2002
Russell Nelson wrote:
> > > > For example the issue of adapting the region
> > > > to displayed map (as Carl has mentioned before) would drive you crazy
> > > > if you are doing some modeling using a larger number of maps with
> > > > different extent and resolutions and you need to preview those maps,
> > > Wait a second. You mean that the region is only used for viewing??
> > No. As well as viewing, the region is also used when generating new
> > raster maps (which is probably *the* most important function of
> > GRASS).
Even more significantly, it's also used when reading existing raster
maps. With a few exceptions, input maps are resampled according to the
current region settings.
> Double aha! Okay, so I suggest these changes:
> 1) don't ask for a default region. If a program needs one, it should
> say "Please set the region that this program should write to using g.region".
But *most* programs need a region. The region concept is so pervasive
that it just isn't worth complicating the majority of programs to
allow for the possibility of there not being a current region.
Especially when all that it would achieve would be to allow newbies to
defer learning about the region for a minute or two.
It might be worth making it easier to automatically create a suitable
location when importing a raster. But the main problem there is that
the data being imported is frequently uncorrelated, so the projection
and the coordinates *must* be specified by the user.
Glynn Clements <glynn.clements at virgin.net>
