[GRASS5] A naive opinion on how grass *should* work
Russell Nelson
nelson at crynwr.com
Fri May 3 10:11:54 EDT 2002
Glynn Clements writes:
> Even more significantly, it's also used when reading existing raster
> maps. With a few exceptions, input maps are resampled according to the
> current region settings.
Didn't people just tell me that I could change it any time I wanted?
How can I do that if my input maps got resampled?
Okay, so in order to learn anything, I have to know everything?? This
is NOT good. GRASS should allow me to import a raster map, and should
set the region to match it, if it's the first map loaded. If I import
another map, and it's going to be clipped (I don't know -- is it??),
or resampled (apparently), then the r.in.* program should say so.
GRASS should *always* do the right thing by default, and say what it
did. If a user asks it to do something that doesn't make sense, GRASS
should do it anyway, and print a warning.
> But *most* programs need a region. The region concept is so pervasive
> that it just isn't worth complicating the majority of programs to
> allow for the possibility of there not being a current region.
You could be quite right. Please respect my newbie experience telling
you that region-setting is difficult and confusing. The defaults are
not reasonable and have no relationship to the data I'm trying to
import or view.
> Especially when all that it would achieve would be to allow newbies to
> defer learning about the region for a minute or two.
Even if all they can do is run grass and type "help", that is a
valuable addition. I think you've forgotten how frustrating it is not
even to be able to start up a program without needing to be an expert!
I appreciate your expertise, and thank you for responding to my
concerns. But understand that my ignorance is valuable, too (while it
lasts :).
> It might be worth making it easier to automatically create a suitable
> location when importing a raster. But the main problem there is that
> the data being imported is frequently uncorrelated, so the projection
> and the coordinates *must* be specified by the user.
Unless it's already georeferenced. I thought that was the whole point
of GeoTIFF -- to carry the projection and coordinates around with the
raster data itself.
-russ nelson http://russnelson.com | Okay, enough is enough!
Crynwr sells support for free software | PGPok | Can we PLEASE all stop
521 Pleasant Valley Rd. | +1 315 268 1925 voice | using insecure Microsoft
Potsdam, NY 13676-3213 | +1 315 268 9201 FAX | email products???
