[GRASS5] A naive opinion on how grass *should* work
Russell Nelson nelson at crynwr.com
Fri May 3 11:36:56 EDT 2002
Helena Mitasova writes:
 > The ease of use of GRASS is really a matter of a good GUI
I don't think so.  Please read my essay "Recollection vs. Recognition"
at http://www.advogato.org/article/100.html
 > Most of your problems aren't really problems and are just a matter
 > of creating a better startup for first timers - that could be done
 > in a week or two.
Exactly what I'm suggesting.
 > >  > Yes; the default region is explicitly chosen by the user. Same for the
 > >  > current region. The only time that the current region is changed is if
 > >  > the user decides to change it.
 > > That is how it currently works.  I am asking you to change it.
 > I am not sure that anybody who has been using GRASS would agree
 > with you on this one.  For analysis and modeling the concept of
 > region as it is now makes a lot of work more efficient.
No, no, I'm not saying that having a default region is bad.  I'm
saying that it's bad to force a first-time user to set the region,
without any knowledge or experience or teaching on which to base their
decision.
Very simply: If I can run grass, and a program says "run g.region
first", I can at very least say "g.help g.region".  If I can't even
get into grass, I'm HOSED.
 > The point is that if you want to do anything beyond looking at the
 > maps you need to know what you are doing. If you want just to look
 > at maps, you are looking at the wrong software.
But how am I going to find out what I'm doing unless I can start doing
things?  Remember, a user who cannot set the region is *locked out* of
grass.  They are stopped dead in the water.
-russ nelson              http://russnelson.com | Okay, enough is enough!
Crynwr sells support for free software  | PGPok | Can we PLEASE all stop
521 Pleasant Valley Rd. | +1 315 268 1925 voice | using insecure Microsoft
Potsdam, NY 13676-3213  | +1 315 268 9201 FAX   | email products???
