[GRASS5] g.region G_usage() commented out?
Russell Nelson
nelson at crynwr.com
Wed May 15 11:31:41 EDT 2002
Glynn Clements writes:
> Russell Nelson wrote:
> > So, you're saying that the entire die() function is not wisely implemented?
> No, I'm saying that the way in which the "description" fields are
> initialised isn't a good idea.
Ahhhh, I see. Okay, then I'll leave that alone and add double
scanning/bounds-checking to G_{lat,lon,llres}_scan, and remove the
MARKER code (if it is indeed silly).
-russ nelson http://russnelson.com | Okay, enough is enough!
Crynwr sells support for free software | PGPok | Can we PLEASE all stop
521 Pleasant Valley Rd. | +1 315 268 1925 voice | using insecure Microsoft
Potsdam, NY 13676-3213 | +1 315 268 9201 FAX | email products???
