[GRASS5] i18n for tcltkgrass
Glynn Clements
glynn.clements at virgin.net
Sat May 18 07:07:28 EDT 2002
Alex Shevlakov wrote:
> > I still think it should be mostly folded into 5.1.x.
> > But right now it looks like stuff will go into 5.0.1
> > or 5.0.2,
> > if it is stable.
> I hope it is stable. The only question is if i18n breaks some systems
> with separate libintl.
The changes to libgis will.
> libgis - done, .po file exists; (Alex). Should the Gmakefile be
> modified to be linked to $INTLLIB?
The simplest fix is to change the definition of GISLIB in make.mid,
i.e.
GISLIB = -lgis $(INTLLIB)
Otherwise, every program which linked against libgis would need to
have $(INTLIB) added to the link command.
> It compiles without it.
It will on Linux, as dgettext() etc are part of GNU libc. On platforms
with a separate libintl, the only programs which will link
successfully are those which explicitly link against libintl, i.e.
grass.postgresql/* and s.surf.rst.
Glynn Clements <glynn.clements at virgin.net>
