[GRASS5] g.region G_usage() commented out?
Russell Nelson nelson at crynwr.com
Sun May 19 22:48:20 EDT 2002
Glynn Clements writes:
 > Are you sure about the removal of the "marker" code? I would guess
 > that it's there for a reason (although I have no idea what that reason
 > might be).
Reasonably.  I tracked down all the subroutines called to make sure
they are happy with a null string.  Perhaps it's something left over
from the Fortran code?  I seem to recall needing to put such things
into Fortran prorgams.
-russ nelson              http://russnelson.com | Nelson's principle: when
Crynwr sells support for free software  | PGPok | someone proposes a solution,
521 Pleasant Valley Rd. | +1 315 268 1925 voice | always ask for a definition
Potsdam, NY 13676-3213  | +1 315 268 9201 FAX   | of the problem it solves.
