[GRASS5] g.region G_usage() commented out?
Russell Nelson
nelson at crynwr.com
Mon May 20 17:19:55 EDT 2002
Glynn Clements writes:
> It still changes the semantics of the function. The existing version
> will reject strings which contain trailing whitespace, due to:
> if (h[1] != MARKER)
> return 0;
> If the marker is removed, G_strip() will strip any trailing whitespace
> before the test is performed.
True enough. Is this behavior anybody wishes to preserve?
-russ nelson http://russnelson.com | Nelson's principle: when
Crynwr sells support for free software | PGPok | someone proposes a solution,
521 Pleasant Valley Rd. | +1 315 268 1925 voice | always ask for a definition
Potsdam, NY 13676-3213 | +1 315 268 9201 FAX | of the problem it solves.
