[GRASS5] another approach to i18n for tcltkgrass; former one revoked
Alex Shevlakov
sixote at yahoo.com
Tue May 21 07:42:40 EDT 2002
--- Glynn Clements <glynn.clements at virgin.net> wrote:
> Alex Shevlakov wrote:
> > makes tcltkgrass slow.
> Are you referring to the startup, or to normal
> operation?
I was referring mainly to load time (startup).
This made things slow in overall, though. I used a
make-up file combined of about 100
:msgcat:mc 'eng_message' 'ru_message' lines. The test
showed slow. This is why I think of not using msgcat.
> BTW, is the "msgcat" package written in Tcl, or does
> it use the
> functions from libintl/libc?
This is TCL.(:(
proc msgcat::mc {src args} {
# Check for the src in each namespace starting
from the local and
# ending in the global.
variable msgs
variable loclist
variable locale
set ns [uplevel 1 [list ::namespace current]]
while {$ns != ""} {
foreach loc $loclist {
if {[info exists msgs($loc,$ns,$src)]} {
if {[llength $args] == 0} {
return $msgs($loc,$ns,$src)
} else {
return [uplevel 1 \
[linsert $args 0 ::format
$msgs($loc,$ns,$src)]]
set ns [namespace parent $ns]
# we have not found the translation
return [uplevel 1 \
[linsert $args 0 [::namespace origin
mcunknown] $locale $src]]
> > This is why using msgcat for the purpose of i18n
> seems to me not a
> > good choice now.
> > Another method would be to place the translated
> script 'menu.tcl' and
> > modules scripts to src/locale/$LCL/tcltkgrass
> directory and copy them
> > if they are needed to $GISBASE/tcltkgrass.
> That would mean that the locale was fixed at install
> time; it should
> be determined at run time, according to $LANG or
> $LC_MESSAGES.
Please see the locale/Gmakefile. If $LCL is defined at
run-time, it is defined the same for mofiles and
tcltkgrass, i.e., once define both.
--alex
__________________________________________________
Do You Yahoo!?
LAUNCH - Your Yahoo! Music Experience
http://launch.yahoo.com
