[GRASS5] Re: [GRASSLIST:3695] Grass5.0.0pre4's 'make install' dies looking for dist.X/locale
Glynn Clements glynn.clements at virgin.net
Tue May 21 13:37:15 EDT 2002
Markus Neteler wrote:
> Let's go for the update. I can do that (welcome pre5).
> Glynn, could you check if we can use the pre4 branch? It should
> be still in a good condition.
The only changes between pre4 (release_13_may_2002_grass5_0_0_pre4)
and the current state of the release branch (releasebranch_26_april_2002_5_0_0)
are:
documents/cygwin_grass50bininstall.html
	Additional information regarding the "sunrpc" package
html/index.html
html/searchhtml.html
	Change "search" form URL from uni-hannover.de to itc.it.
src/raster/r.sun/main.c
	Remove debugging fprintf()
src/raster/r.tiff/r.out.tiff.c
	Fix buffer allocation bug
Note: the actual issue (command failing if "locale" doesn't exist)
still needs to be fixed. I suggest simply omitting the "test", i.e.
${SHELL} -c "cd ${GISBASE} ; tar cBf - locale | (cd ${INST_DIR} ; tar xBf - ) 2>/dev/null ; true"
This will print an error message, but will succeed, and so won't
terminate the installation prematurely.
To eliminate the error message, simply have GISGEN.sh create the
locale directory.
Glynn Clements <glynn.clements at virgin.net>
