[GRASS5] Re: proj bug
Jaro Hofierka
jhofier at unity.ncsu.edu
Thu May 23 07:36:48 EDT 2002
Markus Neteler wrote:
> Hi Jaro,
> (cc grass5)
> On Wed, May 22, 2002 at 03:20:55PM -0400, Jaro Hofierka wrote:
>>Markus,
>>I replaced main.c and bordwalk.c in r.proj and it works now. I have used
>>versions from mid-March release. Later I'll try to figure out what is
>>wrong there.
> Did you also try v.proj? The same problem occurs for me (in any
> location, even the old ones).
Yes, it works OK. But I had to replace recent source files found in
r.proj, v.proj, s.proj by older versions from CVS snapshot experimental
dated March 15.
J.
