[GRASS5] Re: [bug #1052] (grass) [rsv].proj are crashing
Roger Miller
rgrmill at rt66.com
Thu May 23 07:36:04 EDT 2002
On Thursday 23 May 2002 02:26, Markus Neteler wrote:
> Following fix cures the problem for env.c:
> cvs diff -u env.c
> RCS file: /grassrepository/grass/src/libes/gis/env.c,v
> retrieving revision 1.5
> diff -u -r1.5 env.c
> --- env.c 12 May 2002 12:04:45 -0000 1.5
> +++ env.c 23 May 2002 08:25:33 -0000
> @@ -177,13 +177,12 @@
> int n;
> for (n = 0; n < count; n++)
> - if (env[n].name && (strcmp(env[n].name, name)==0))
> + if (env[n].name && (strlen(name)!=0) && (strcmp(env[n].name,
> name)==0)) {
> free (env[n].name);
> env[n].name = 0;
> return 1;
> return 0;
> Objections to submit this fix?
Markus, if an empty string caused the problem, then maybe a better fix would
be to change set_env so that an empty string never stored. An empty string
could be treated like a NULL.
At line 125 in env.c the statement
if(!value)
could be changed to
if(!value || !strlen(value))
That way an empty string is treated the same way as sending a NULL string and
causes GRASS to unset the environment variable.
> But...
> Then the next bug occurs due to the new NAD datum support:
> In r.proj/main.c line 279 is the function G_database_datum_name() used:
> strncpy(in_datum,G_database_datum_name(),sizeof(in_datum));
> For my existing locations it returns NULL which causes a crash
> of strncpy(). The function G_database_datum_name() is in
> src/libes/gis/proj3.c
> How to solve that one (hi Roger)? Therefore [vs].proj are also affected.
Uhh. I guess I did know about that problem. A check is easily added. My
preference would be also to change G_database_datum_name() so that it does
not return NULL (maybe returning a pointer to "unknown" instead) and/or
ensuring that the datum is never blank.
Roger Miller
