[GRASS5] make install failing on "locale"...
Eric G. Miller
egm2 at jps.net
Fri May 24 01:48:20 EDT 2002
Is this make bug w.r.t. locale/ supposed to be fixed? I causes make to
exit here.
test -d /usr/local/src/grass/dist.i686-pc-linux-gnu/locale && test -d
/usr/local/grass5/locale || mkdir -p -m 755 /usr/local/grass5/locale
test -d /usr/local/src/grass/dist.i686-pc-linux-gnu/locale && /bin/sh -c
"cd /usr/local/src/grass/dist.i686-pc-linux-gnu ; tar cBf - locale | (cd
/usr/local/grass5 ; tar xBf - ) 2>/dev/null ; true"
make[1]: *** [real-install] Error 1
make[1]: Leaving directory `/usr/local/src/grass'
make: *** [install] Error 2
Note: I don't have NLS enabled so there isn't a dist.<foo>/locale
directory...
Eric G. Miller <egm2 at jps.net>
