[GRASS5] R/Grass interface under Windows
Markus Neteler neteler at itc.it
Fri May 24 05:13:26 EDT 2002
On Fri, May 24, 2002 at 11:06:21AM +0200, Moritz Lennert wrote:
> Hi all,
> A question came up on the French mailing list:
> Can the R/Grass interface be used under Windows, or does it contain anything that makes it platform-dependent ?
Hi Moritz,
you can directly use it (some people here do that). The trick is
to copy some files required by R/PERL into the appropriate
directory. Then
R CMD INSTALL GRASS
will work inside the Cygwin terminal.
The R/GRASS prints some warnings, but they can happily ignored.
Cheers
 Markus
