[GRASS5] [bug #1060] (grass) precision problem in i.points/image library
Request Tracker
grass-bugs at intevation.de
Fri May 24 09:51:51 EDT 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1060
Subject: precision problem in i.points/image library
grass binary for platform: Compiled from Sources
GRASS and NOAA AVHRR data
It seems that we have a precision problem in i.points resp.
the underlying transformation library. NOAA/AVHRR data, imported
with latest GDAL/r.in.gdal contain thousand of ground control
points (GCPs), ordered row-wise.
The snapshot of i.points shows that there is a regular dis-location
of points in the target location while correct in source location.
This introduces an error which is not desired.
The example: ipoints_noaa.gif (88kb)
http://mpa.itc.it/markus/noaa/
shows in the left part the raw AVHRR in XY location, in the right
part the GCPs in Lat/Long. The lower right window shows that
the GCPs are no longer in a curve, but show a regular offset.
Help is desired to solve this problem.
Markus
-------------------------------------------- Managed by Request Tracker
