[GRASS5] [bug #1062] (grass) [GRASSLIST:3762] missing features ?!
Request Tracker grass-bugs at intevation.de
Mon May 27 04:59:08 EDT 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1062
--=.B)_3cklk_p:VbB
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Dear List,
after updating from cvs the -l-option from v.in.shape was gone ;-(
Older versions of v.in.shape had the switch -l for displaying all
attributes in the .dbf-file of the shape.
Would it be a big deal to implement it in the rewritten version of
v.in.shape?
thank you
cheers
  steph
Linux: the operating system with a CLUE...
         Command Line User Environment.
Stephan Holl  		GPG: 11946A09
sholl at gmx.net
ICQ# 117277975
http://frosch.2y.net
--=.B)_3cklk_p:VbB
Content-Type: application/pgp-signature
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.6 (GNU/Linux)
iD8DBQE88fHeEg9SKhGUagkRAplwAJ4ga+cTCc8pG8mgi1bH+Wu1X8vSZwCglTIE
EJ0t5wZ0EuWWSWk36li8bMs=
=+MMK
-----END PGP SIGNATURE-----
--=.B)_3cklk_p:VbB--
--- Headers Follow ---
>From neteler at itc.it  Mon May 27 10:58:54 2002
Return-Path: <neteler at itc.it>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
	by lists.intevation.de (Postfix) with ESMTP id 397EF13922
	for <grass-bugs at lists.intevation.de>; Mon, 27 May 2002 10:58:54 +0200 (CEST)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
	by mail.intevation.de (Postfix) with ESMTP id 9F5361B6D6
	for <grass-bugs at intevation.de>; Mon, 27 May 2002 10:58:52 +0200 (CEST)
Received: from orchestra.itc.it (orchestra [10.0.10.11])
	by camelot.itc.it (8.11.3/8.11.3) with ESMTP id g4R8wpn04061
	for <grass-bugs at intevation.de>; Mon, 27 May 2002 10:58:51 +0200 (MET DST)
Received: from thuille.itc.it. (thuille [10.40.0.110])
	by orchestra.itc.it (8.11.6/8.11.6) with ESMTP id g4R8wpK32143
Received: (from neteler at localhost)
	by thuille.itc.it. (8.11.6/8.11.2) id g4R8wpC15786
	for grass-bugs at intevation.de; Mon, 27 May 2002 10:58:51 +0200
Resent-Message-Id: <200205270858.g4R8wpC15786 at thuille.itc.it.>
Received: from camelot.itc.it (camelot [195.223.171.5])
	by orchestra.itc.it (8.11.6/8.11.6) with ESMTP id g4R8uaK31930;
	Mon, 27 May 2002 10:56:36 +0200
Received: from ccis01.baylor.edu (ccis01.baylor.edu [129.62.1.18])
	by camelot.itc.it (8.11.3/8.11.3) with ESMTP id g4R8uYn04000;
	Mon, 27 May 2002 10:56:34 +0200 (MET DST)
Received: from localhost (localhost [127.0.0.1])
	by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id DAA1080194;
	Mon, 27 May 2002 03:54:07 -0500 (CDT)
Received: from FS-EXCHANGE1.baylor.edu (flopsy.baylor.edu [129.62.3.249])
	by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id DAA1052429
	for <GRASSLIST at listproc.baylor.edu>; Mon, 27 May 2002 03:51:12 -0500 (CDT)
Received: from waylon.baylor.edu ([129.62.3.228]) by FS-EXCHANGE1.baylor.edu with Microsoft SMTPSVC(5.0.2195.4561);
	 Mon, 27 May 2002 03:50:46 -0500
Received: from its07.baylor.edu ([129.62.3.167]) by waylon.baylor.edu with Microsoft SMTPSVC(5.0.2195.4561);
Received: from willie.baylor.edu (willie.baylor.edu [129.62.3.227])
	by its07.baylor.edu (Switch-2.1.1/Switch-2.1.1) with SMTP id U4R83E9W07694
	for <grasslist at baylor.edu>; Mon, 27 May 2002 03:50:45 -0500
Received: from mailout07.sul.t-online.com ([194.25.134.83])
 by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002052703504528962
Received: from fwd08.sul.t-online.de
	by mailout07.sul.t-online.com with smtp
	id 17CGDe-0000gx-00; Mon, 27 May 2002 10:51:10 +0200
Received: from superserv.wg.de (510007208979-0001@[62.226.96.233]) by fmrl08.sul.t-online.com
	with esmtp id 17CGDL-25uVXsC; Mon, 27 May 2002 10:50:51 +0200
Received: from kermit (kermit.wg.de [192.168.0.99])
	by superserv.wg.de (8.11.0/8.11.0/SuSE Linux 8.11.0-0.4) with SMTP id g4R8iDl21148
	for <grasslist at baylor.edu>; Mon, 27 May 2002 10:44:13 +0200
X-Authentication-Warning: superserv.wg.de: Host kermit.wg.de [192.168.0.99] claimed to be kermit
Date: Mon, 27 May 2002 10:44:11 +0200
To: GRASSMailinglist <grasslist at baylor.edu>
Subject: [GRASSLIST:3762] missing features ?!
Message-Id: <20020527104411.14b7e2c3.sholl at gmx.net>
Organization: Steph_online
X-Mailer: Sylpheed version 0.7.6cvs14 (GTK+ 1.2.10; i686-pc-linux-gnu)
X-Face: -{$[a7]BuCiI~[,d73pjgpw)xiR.j32#XZX'{kN|I0&qsMj,>?_v`NqGicEXwL at iT=5IAbV 3`[[K4!%v6%Uec]^>`ASniTdaY{oLJ]|2I}9 at s`>^mf_{\J?1etIm(b
Mime-Version: 1.0
Content-Type: multipart/signed; protocol="application/pgp-signature";
 boundary="=.B)_3cklk_p:VbB"
X-Sender: 510007208979-0001 at t-dialin.net
X-OriginalArrivalTime: 27 May 2002 08:50:46.0055 (UTC) FILETIME=[976E5B70:01C2055B]
Sender: owner-GRASSLIST at baylor.edu
X-Listprocessor-Version: 8.2.10/991025/16:55 -- ListProc(tm) by CREN
Resent-From: neteler at itc.it
Resent-Date: Mon, 27 May 2002 10:58:51 +0200
Resent-To: grass-bugs at intevation.de
X-Spam-Status: No, hits=0.0 required=5.0 tests=PLING,DEAR_SOMEBODY version=2.20
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
