[GRASS5] problems with [rsv].proj
Markus Neteler
neteler at itc.it
Mon May 27 05:30:08 EDT 2002
On Fri, May 24, 2002 at 07:09:29PM -0400, rgrmill wrote:
> Folks,
> I committed changes to datum_shift.c to test for null values of the datum
> names. I also committed changes to correct the "dubious behavior" that
> Eric pointed out in r.proj and did the same for v.proj and s.proj.
> I compiled the code and ran the updated r.proj without problems. I have
> not run v.proj or s.proj. Further, all my test locations have their datum
> and ellipse specified, so they don't actually test the new code. In
> brief, more testing is advisable.
Roger,
the v.proj seems to work now without datum/ellipse (tested for lat/long)
while r.proj continues to crash.
Please test the code again, you could disable datum/ellipse in
PROJ_INFO with # easily.
Markus
